Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: ECS Clutch
  1. #31
    Jun 2009
    PJ/Selangor, Malaysia
    slower changes? try the dogmount. that makes the change more accurate and you can swap cogs much quicker.
  2. #32
    Nov 2008
    Canberra
    I don't have crunching, but the changes can be slower than I would like.
    Does the Redline help with the changes over all?
    Seemed to smooth things up a bit as well as eliminating the crunch. But I've always tried not to slam changes super fast the way you can in, say, an MX5.
  3. #33
    Nov 2008
    Canberra
    Quote Originally Posted by jesum View Post
    Ive got the dogbone, and I think noone has too.
  4. #34
    Jan 2009
    blankedy
    I have the dogmount. My car (06) has the first gearbox which does not seem to be as troublesome as some of the later models. The changes happen fine, but its just a little clunky at times (especially when the revs are not matched).
    Think I'll have a search around, have not looked at the gearbox threads particularly before.
  5. #35
    Oct 2009
    Canberra
    I too have th dog bone mount. It has made changing gears smoother and less clunky. I've only grinded once when going up in gears. Reversing a few times.
    But will definitely also look into the Redline MTL and also give that a go.
  6. #36
    Mar 2009
    Sydney {GO BLUES}
    Back on topic
    which one did u ppl go for?
    the ecs stage 1 http://www.ecstuning.com/Volkswagen-...Clutch/ES1387/
    or the vw stage 1 http://www.ecstuning.com/Volkswagen-.../Clutch/ES125/
    the only difference i can work out is 7lbs but is that worth the extra $300+??
    APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
    139Kw | 271.8Nm atw - At a new home
  7. #37
    Dec 2006
    the vw stage 1 mate
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
  8. #38
    Mar 2009
    Sydney {GO BLUES}
    I just wanted to know how you uppl removed the g/box.
    did you remove the subframe and brace the motor or can u leave subframe and juggle the box out?
  9. #39
    Jan 2009
    sunshine coast
    id be asking jmac that question. no doubt hes done a few and when/if i ever get around to doing those upgardes no doubt ill be asking him to do the install as well.
    " I wait I resolution derive pleasure this " latest spammer post
  10. #40
    Aug 2007
    Cheers Mike, to answer the question the subframe stays in on the Pog.
    Jmac
    Alba European
