lmao its all good if he attempts to leave town well blockade his front door with polo's
" I wait I resolution derive pleasure this " latest spammer post
I'm up for that Mike!!!
Peroni will stop him leaving.
He has it down to about 3 hours now I think. He has fitted so many Polo clutch kits.
My clutch on my pog is starting to go....
So what do you guys recon? 14lb ecs? who can i buy it from?
APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
139Kw | 271.8Nm atw - At a new home
i just order the golf mkIV clutch dont i?
So I installed the dog bone last Wednesday cause I thought it would help to not grind the gears. Unfortunately it happened again when shifting from 2nd to 3rd around 4500rpms. I hate the grinding sound.
So my question is if I get Stage 1 or 2 clutch with a lighter fly wheel will this further reduce gear grind?
Would a stage 1 clutch upgrade suffice if I choose to upgrade to a K04-001 later down the track? I also checked the ECS website and found a number of K04 variants, do I have to stick with the K04-001 or is this the perfect model that slips in and replaces the K03?
the k04 -001 is the direct bolt on , the other k04's require more stuffing around. if your after a lil more power out of the k04-001 , try a hybrid.
