Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: ECS Clutch
  1. #21
    Oct 2009
    Canberra
    I was just curious as all as some of the other K04 are quite a bit chearp than the 001.
  2. #22
    Jan 2009
    Not sure that a uprated Clutch is going to help the grinding gearbox.
    If anything it is just going to push more strain in its direction
  3. #23
    Oct 2009
    Canberra
    It doesn't grind all the time just on a few occasions when I give it to the Pog.
    I just thought that it could be the clutch that could be the cause of the gears grinding by not fully engaging / disenaging properly at high/er revs.
  4. #24
    Jan 2008
    Ferntree Gully
    Quote Originally Posted by Servo View Post
    POGs love to grind there gears. The best thing I can recommend is the following:
    1. Put the handbrake on and your foot on the brake.
    2. Without using the clutch, slightly push the gearknob into the gear that often grinds. You will notice that the engine RPMs drop. Hold it here for say 5-15 seconds.
    3. Repeat step 2 a few times, as needed.
    It sounds completely ****ed up I know - there is some other dude here that explained the whole thing, and honestly, my gearbox which was a grindasorous after a factory rebuild barely ever grinds anymore.
  5. #25
    Oct 2009
    Canberra
    Anything is worth a try, I'll see how this goes.
  6. #26
    Jan 2008
    Ferntree Gully
    Have you modded your car etc?
    I'm in the ACT till the end of next week if you wanna check out a APR'd polo with a FMIC.
    Cheers,
    Jarrad
  7. #27
    Oct 2009
    Canberra
    Yep, chipped it when I clicked it at 900km. Trauling through these forum didn't help resist the temptation. Got the RSW, dog mount and rear control arm bushes the other week. Now just saving for the Bilstein B14, FMIC and down pipe and then stage 2 reflash.
  8. #28
    Aug 2007
    Uprated clutch wont help if you are grinding gears. Clearance of the ECS clutch is pretty much OEM so the same clearance same grinding. I suggest changing your gear oil to an oil with more friction, Redline MTL goes very well in the 02R Polo Gearbox, after around 200-300 clicks it should feel heaps better.
    Jmac
    Alba European
  9. #29
    Nov 2008
    Canberra
    I'll endorse Jmac's advice. MTL cured the grinding in mine. Grinding started at 2k, Redline in at 4k, no further problem now at 9k.
  10. #30
    Jan 2009
    blankedy
    I don't have crunching, but the changes can be slower than I would like.
    Does the Redline help with the changes over all?
