No cat for a start, so you need to be prepared for that. It's cheap enough to throw away if it doesn't.
Do you reckon this downpipe will fit the Polo GTI? it's cheap.
http://cgi.ebay.com.au/VW-Golf-GTi-B...item3cab558f9f
No cat means you need code that allows for the bypassing of the sensor thats associated with the cat.
Bend does not look sharp enough, I'd assume it may need some work...
Looks cheap and pretty poorly made. Plus having no cat as well.
Well I got the stainless 3" down pipe (good quality and nice TiG welds, included gaskets), I thought I'd take the gamble as it was $179A landed. I have a mate with a TiG so I thought worst case, I can do a cut 'n' shut job, but all I had to do was take 60mm off the end and it fit perfect - it also has the sensor connections so no error messages![]()
So... any downpipe made for golf mk4 gti would fit just by cutting a bit from the end of it ?all I had to do was take 60mm off the end and it fit perfect
