Results 1 to 10 of 15
Thread: Easy way to remove rear wheels from hub?
    Jun 2008
    Hi all
    Is there an easy trick for getting the rear wheels off the hub, held on by rust on the hub?
    when I'm rotating tyres at home I have the car on trolley jack and a perfectly flat garage floor so a few well placed kicks on the tyre once all the bolts are out will do the job.
    However kicking the tyre would be something I'd be reluctant to do if I'm changing tyres on the road with with the car on a scissor jack and non level ground...
    Oct 2006
    Sep 2006
    Brisvegas
    I had the same issue. Rang vw assist. They said to put the nuts on till there tight and then backthem off a turn or 2 and then go and take a quick spin making sure you do a hard uturn. Then go back and it should be right.
    I did this and worked fine but I'm not going to recomend it just in case something happens . But it's up to you.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Eastern suburbs of Melb
    Sep 2006
    Australia?
    Quote Originally Posted by Flaps View Post
    Quote Originally Posted by thestu View Post
    LOL
    Yep pretty much if that fails well then your screwed
    Apr 2006
    Hobart,Tas
    Always leave one bolt loosely in the hub to stop the wheel from falling on the ground!!!
    I hit the tyre with a long bit of pipe to jar them loose. And I clean up the hub with emery and apply a dab of grease there to stop further problems.
    Good luck!!!
    Andrew
    Aug 2007
    Spin the wheel and hit with the bolts loose and hit the wheel works for me everytime, hit the wheel from the inside though.
    Jmac
    Alba European
    Jun 2008
    Perth
    would be nice if they didn't rust in the first place...kina looks pretty cheap
    Feb 2008
    Even the best have bad days...I had Jim Richards and Barry Oliver borrow my 19mm socket and breaker bar at the 2006 Buller Sprint after they pulled into where we were sitting at one of the Hairpins before Mt Buller Village as both of their Rear wheels on hes 911 Turbo(can't remember if it was a 996 or 997) had come loose on the way up the hill! He had no idea why they were loose, and said he had torqued them up correctly before the start of the event.
    I always found that Spray Penetrant like Cartrol DWF or CRC was good to loosen wheels off hubs(we get alot of rusting between wheels and hubs in the tropical climates).
