Results 11 to 20 of 28
Thread: Dyno results after Full Non-Res Milltek, Forge FMIC and Forge diverter valve fitted!!
    Aug 2009
    I can't imagine why you'd spend all that money on those mods, instead of doing the remap first *shrugs* It's a backwards way of modding a Polo to me.
    Robihe, the FMIC in our case does not add power, it maintains the power by keeping the intake temps down.
    Yes, and no. It does actually slightly sap power due to pressure loss, it also will add lag. It's a matter of if the temperature reduction can allieviate the negative effects, and for the quality intercoolers I'd imagine they would be close to neutral benefit to power. But yes consistency of power, particularly on a hot day, is the big draw card for most people.
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Put your stock intercooler back on - if you have lost ~ 4 psi of boost (as many other have) then on a stock car (no upped boost with software) then you are lucky to get those gains!
    Jan 2009
    Bucharest, Romania
    Here's my before/after forge fmic dyno:
    The ecu map was stock at that time. And only other mod was "pd160 intake".
    Aug 2006
    Melbourne VIC
    Ohhhh.
    Yes think its time for a GIAC, CC, APR or Revo tune mate.
    Aug 2009
    Belgium
    Quote Originally Posted by break View Post
    Sounds to me that you are the one with the backwards modding idea mate
    first hardware, after that, software,
    specially when you are going to get a custom remap.
    ps: IC is allways better on a turbocharged engine.
    you might get a bit turbolag on a stock engine if the IC is a bit to large, otherwise you will not notice it at all.
    but it's still worth putting it even if you have a bit more lag.
    heatsoak will be elliminated, and thats a factor where Polo GTI's have real problems with.
    still it's everyone on it's own, it's a personal choise..
    Mar 2008
    Quote Originally Posted by instigator View Post
    The remaps here aren't custom though are they? Are they preset or do they change depending on mods?
    melbourne
    i've heard that revo's are preset, and that others work off your stock map, tweaking the different parameters.
    i thought that if you wanted a custom tune, it would have to actually be custom, as in someone comes around to your place and does a rolling road tune, or you take it to someone like evolve technik and get dyno tuned?
    as far as i can gather, anything whereby you get maps, however powerful they are, without the mapping process taking place whilst the wheels are rolling, is classified as an ''off the shelf'' tune?
    Mar 2010
    Lynbrook, Victoria
    Quote Originally Posted by Buller_Scott View Post
    thats exactly where im getting my phase 2 tune done, by the evolve technik guys. Which required them install the forge kit + b.o.v and exhaust. Did a dyno run once all the mods were fitted, and sent the results to Germany to develop a custom tune for the mods. Got a response over night with 3 different tunes. Now going in tomorrow to do some tests and runs and download the software that is best suited.
    Aug 2009
    If it's a custom remap, sure... but how many of us actually run custom remaps? Isn't CustomCode the only brand that allows any significant adjustability?
    I know most people here are running the standard APR/GIAC/REVO setup, which doesn't receive any benefit from doing it pre or post mods.
    Jul 2007
    Auckland, NZ
    REVO comes in as off-the shelf item, then you can do rolling dyno - to change 1) fueling 2) timing 3) and boost. Setting start from 0(stock) to 9 (maximal performance either, race fuel, advanced timing, or higher boost). So reasonable tweaking can be done. i am on Boost 8, Timing 7, and Fueling 8. Fueling can be also adapted by the ECU itself.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
