Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Dyno done today
    Jul 2007
    Auckland, NZ
    Dyno done today
    Hi guys,
    Dyno done today at Auckland torque performance.
    127.4kw at wheels / 690nm torque (i don't know what this means)
    It was 20 degrees in the building, and got the number on 2nd run.
    Modifications REVO and Seat intake. Engine wise.
    Quite happy with it...
    I know Torque figures are all different from dyno to dyno... MTM A4 Quattro 1.8t got 106kw at wheels.
    Golf GTI with oetingger got 110kw at wheels. (MK4).
    There was MK3 Golf with 2.9 VR6 engine and supercharger or turbo doing 155kw at wheels...
    I think with lower temperature and better BP 98 Ultimate (mine was Mobil 98 which I don't think is as good as BP ones)... and with first run probably maybe able to make 130kw on this dyno.
    Peak torque is at 3500rpm
    Peak Boost is 22.1psi
    AFR - reasonable, but could be improved slightly.
    I don't have a scanner so haven't scanned it yet...
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Jul 2007
    Auckland, NZ
    Read through the past dyno figures from different cars.
    Mine did around 40km run from home, with average speed of 120km/h.
    And was sitting in the burning sun for 1 hour prior to getting the run...
    And air temp of 20 degrees in the building.
    I am happy with my reading then!!
    Jun 2007
    Eastern Suburbs Melbourne
    690 Nm of torque, you sure?
    i like volkswagens
    Sep 2006
    Brisvegas
    yes wouldnt it be reading the torque at the wheels after it has been through the Gearbox (torque multiplier)??
    edit - btw nice figures insane
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Sep 2006
    Brisvegas
    Have a look at timbos revo dyno. He has close to 600nm at 70km/h
    Hope you dont mind me using it timbo
    Have a Look
    CUSTOM CODE
    Phase 2
    Jul 2007
    Auckland, NZ
    Thanks! That's the number I don't understand... Mine is close to 680-690nm on the reading the graph... i will try to scan it at somepoint... just don't understand it.
    Mine is slightly lean which is the worrying part. Very very slightly is what the dyno guy told me. I better get it scanned and put it up.
    Sep 2006
    Brisvegas
    what gear was the dyno run in
    Have a Look
    CUSTOM CODE
    Phase 2
    Dec 2006
    Gold Coast
    Quote Originally Posted by shaneth View Post
    Even if it was in third.
    Torque wouldnt be high from memory?
    Seems rather odd.
    Jul 2007
    Auckland, NZ
    3rd gear I think. I will recheck the sheets. Maybe 2 wheels, so divide it by 2? :-> Hahaha....
    I dunno... All other cars produced high numbers, but I just didn't know how to convert this... to well more reasonable number.
    Sep 2006
    Brisvegas
    Quote Originally Posted by Kai View Post
    Seems rather odd.
    Kai i would have thought it would be higher as dont you divide the torque by the Gear ratio multiplied by the diff ratio???
    3rd gear 1.36
    Diff 3.65
    Have a Look
    CUSTOM CODE
    Phase 2
