Try pressing the button next the the A/C button so it doesn't let outside air in.
Right. The air cons not on and the fan is on zero. But everytime I stop at the same lights after travelling slowly up Military road and then come onto the freeway at speed the fan goes warm and the car almost smells a bit like burning...
I've checked the engine temp and its exactly in the middle each time so that ain't it......Is this normal ? It fades after about 3Kms
Sorry for what could be a really daft question
factory's forever happy water temp isnt a true indication...
Okay after driving on the highway most of my cars life so far here is the answer:
1. Just because the fan isn't going doesn't mean the car isn't pumping hot water through the heater core
2. Once you go above ~60km/h the air pressure coming in the front of the car pushes through the aircon system with the fan on "0". At 100 there is a fair bit of flow.
3. Burning, you sit still with no air flow over the heater core in traffic. The aircon system is still heating the heater core. It gets very hot because you're car is trying to heat the cabin with no airflow.
4. You drive off onto the freeway, you get airflow over your VERY hot heater core = heat plus dust/pollen = slight burny smell?
That is what I have found driving 66km to work on the freeway each day.
Ben,
Nail on head mate, thats whats going on here.....So nothink to worry about huh..Great!
cheers for the explanation.
After my wife rearranged the front end of my car and i got the a/c regassed the fan doesnt seem to spin as fast as it used too.before u could hear the fan now u cant.can someone explain
What's your temperature on? Maybe try turning it to the minimum? i.e. below 18.
