Dreaded Pinging
I just wanted to think aloud in the event anyone is able to shed light on what my car is experiencing.
Mechanically, I just have a GIAC 98 octane tune and a new diverter valve. Under high load, low rpm situations, particularly a 1st/2nd/3rd squirt changing around 3,500rpm, I very rarely experience pinging.
Now these cases haven't neccisarily been in high temp situations (ie. car idling for a long time, or stuck in traffic etc.) nor have they been on hot days (21 degree's outside today). That led me to think it's fuel, but after getting all the injectors professionally cleaned, the fuel filter replaced, and a bottle worth of Nulon injector cleaner run through the car it still hasn't resolved this.
The more I look at the fuel system, the more I suspect heat being the issue. Particularly seeing it's normally 1st/2nd/3rd runs... whereby I come to a brief stop before accelerating, giving heatsoak a chance to set in.
Anyone had anything similar? I'm really not up for forking out for an intercooler upgrade, and beside pulling the front wheel well lining up and checking the air flow to the intercooler and possibly giving it a rear vent into the wheel well, anyone up for any ideas (besides the obvious 'turn the boost down', which is a little hard with nothing but a GIAC tune running at ~20.5psi peak)
Edit: One other thing I'm about to try is cleaning out the MAF to see if that helps. Is there a way to identify a faulty MAF other than VAG logging?
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
