It should not matter which way an angled spacer is orientated, well not with 42DD that I know of. The whole idea is to remove the sensor from the direct flow, and as it is now on an angle it will only sniff a small fraction of the exhaust and be happy. All I can assume is the one you have allows simply too much gas through to the probe, and any sort of physical obstruction you can tack weld or bolt in place will assist such as a mesh between the flow and the probe. I have had a mad run on angled spacers this month, and am totally out, plus have pre sold the ones arriving shortly so it will be weeks before I have more I am afraid.
