Results 21 to 30 of 38
Thread: Downpipe Issues
  1. #21
    Jan 2010
    Just out of curiosity, does anyone have a downpipe with CEL and has just left it?
    Also, when you turn the ignition on, am I right in saying the engine light, handbrake light on and (forget the other light, I think EPS) stay on once the other lights switch off..?
  2. #22
    Jan 2010
    My spacer:
  3. #23
    Jan 2010
    Update
    For some reason, and if you've had this issue before, please chime in...
    Under hard acceleration and revs above 2,500rpm, the CEL never comes on. Always about 100kms after clearing the code, if I drive below 2,500rpm (generally in 4th gear) the code shows up on the dash.
    Would logic tell you that if you're cruising under 2,500rpm, the air flowing through the exhaust system is not reaching the post cat sensor due to the spacer placing the sensor further from the exhaust? Therefore, the ECU reads a CAT deficiency or Bank 1 P1176 error code.
    I think it's now time to start some logging. Can anyone in Sydney help me out here in terms of VAG logging and seeing if the sensor is infact no longer working properly?
    ---------- Post added at 09:08 PM ---------- Previous post was at 04:28 PM ----------
    Would anyone know if a VOLKSWAGEN POLO 2007 MATCH 1.6LTR o2 sensor would be the same as our Polo GTI? Any alternatives other than VW factory stock...
    Jan 2009
    blankedy
    Have you tried the car without a spacer at all?
  5. #25
    Quote Originally Posted by pog View Post
    Update
    The one for the GTI is specific, the pre and post ones are different. 1K0 998 262Q is listed as the new replacement on my ETKA.
    That's not to say the aftermarket don't make a generic one that will work in a million different vehicles. ie The one with the longest lead will fit all the others, where VW go to the trouble of making them with the right length for each model.
  6. #26
    Jan 2010
    Good question, no I haven't. From your experience have you heard anyone with a larger downpipe running no spacer with no CEL?
    ---------- Post added at 03:01 PM ---------- Previous post was at 02:42 PM ----------
    Is it possible to differentiate between pre and post cat o2 sensors?
    The reason I'm asking is because probably the fabricator mixed up the o2 sensors. Front to rear and rear to front. If there is a way, can someone let me know?
  7. #27
    The forward one is part number 06A 906 262 DK and the rear one 06A 906 262 DL
  8. #28
    Jan 2010
    Thanks Gavin, would this be actually written on the sensor?
  9. #29
    Yeah it will be. Can't promise it will be easy to read though.
    You might need an inspection mirror and a torch or take one out. 22mm they are.
  10. #30
    Jan 2010
    What a champion! I'll jack the car up tonight and see if it's written on the sensor or the wiring. God forbid the exhaust shop have them mixed around!
    Also, if they were mixed around, would that interfere with the idle, performance of the car? Sorry for the 21 questions.
