Results 11 to 20 of 38
Thread: Downpipe Issues
    Mar 2009
    Sydney {GO BLUES}
    Did you go to Hax at Performance Exhaust centre? he called me saying one of his customers had the exact same thing you were talking about.
    APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
    139Kw | 271.8Nm atw - At a new home
    Jan 2010
    Quote Originally Posted by bfeboi View Post
    Yeah I did goto Haks. I called him in the morning and he told me he was going to follow up. God I love the guy, man of his word!
    I'm assuming you got the test pipe file from APR with your downpipe.
    Mar 2009
    Sydney {GO BLUES}
    i did the downpipe and apr tune in one go so i don't have any issues that you were referring to
    Jan 2010
    No problem. Will be diagnosed tomorrow. Did Haks do you custom catback?
    Mar 2009
    Sydney {GO BLUES}
    yeah. he did my cat back with 2 resonators and magnaflow back box. I love the sound of it
    Jan 2010
    Link us up to a sound file!
    Also, do you track your car at either Wakefield or EC?
    Mar 2009
    Sydney {GO BLUES}
    i don't have anything that will record with proper audio....
    I've dabbled in the art of tracking at Wakie, EC and Oran Park. Heading to wakie this weekend and aiming for 1'13"***.
    Jan 2010
    No doubt you'll get it. Consider Supersprints like I said last time, it'll be good to have a fellow Polo on course!
    ---------- Post added 14-03-2012 at 08:33 PM ---------- Previous post was 13-03-2012 at 11:59 PM ----------
    In the event that my post cat o2 sensor is gone, (which I don't think it is), does anyone know where I can buy the BOSCH o2 sensor for our car?
    Has anyone had to purchase the VW one? If so, what was the cost..
    ---------- Post added at 08:38 PM ---------- Previous post was at 08:33 PM ----------
    Update: Checked the exhaust bolts, and turbo bolts this afternoon, all good. Must be either:
    a. The post cat o2 sensor
    b. The spacer
    Got this: 17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
    17584/P1176/004470 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
    Possible Causes
    Intake Air System leaking
    Oxygen Sensor(s) and/or Oxygen Sensor Control faulty
    Possible Solutions
    Check Intake Air System for Leaks (False Air) - Will get the car smoked for leaks
    Check Oxygen Sensor(s) and/or Oxygen Sensor Control (all of them!) I'm sure it's this!
    Aug 2007
    Perth WA
    '04 BMP MkIV R32 #144
    search getnew
    Jan 2010
    Just an update with background so far
    •Added 3" downpipe with 200 cell cat with spacer to avoid CEL
    •CEL shows up 60 kms later.
    •Turns out the spacer is facing to the rear of the car. Switched to face towards the front of the car (drivers side) and clear fault code.
    •CEL shows up again 80kms later.
    •Disconnected the battery for 30 minutes, unplugged the MAF, reconnected everything again and checked the exhaust bolts.
    •CEL shows up 262kms later.
    Car awaiting to be looked at on the 24th March. Going to be smoked for boost leaks and a check over again. May be running to lean or to rich, for gods sakes, I have no idea.
    Will keep you all updated.
