Results 1 to 10 of 15
Thread: does the Polo GTI use an ODBII interface?
    Jun 2009
    PJ/Selangor, Malaysia
    as the question says, does it use an OBDII interface? i've seen the port under dash near the steering column but i am not familiar with the pin layout (not a very geeky fellow in car interfaces).
    Jul 2007
    Auckland, NZ
    OBD 2 I believe yes.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Jan 2009
    blankedy
    Whats your plan? You can get a OBDII To Serial (D9) cable from Ebay UK for about $30...
    Jun 2009
    This -> Carman
    since it's built on something called Python, it is a lot easier to hack but it will depend on what the OBD2 plug-in module exposes.
    there are a few devices that reportedly work with carman (this one does -> DealExtreme: $53.99 ELM327 Bluetooth OBD-II Wireless Transceiver Dongle).
    Jan 2010
    Hey fellas I was wondering if we have the obd2 port? I'm thinking of getting a canobd2 device which scans for errors etc... E.g Welcome to CanOBD2!
    I guess before I purchase, would this be okay to use with the 9n3 gti's? Cheers
    Jan 2009
    blankedy
    Be aware, I don't think you can get boost from these controllers as the ECU does not have a boost pressure sensor. My understanding is that with our cars, Boost is calculated from some other data.
    Pog, make sure it can clear codes as well as scan them, otherwise you'd end up with something that can only really do what a $30 cable and a lappy can do...
    Jan 2009
    blankedy
    Whatever OBDII is...
    Mar 2007
    Gold Coast
    Is there any difference between the ebay uk ones and the ones on Aussie ebay from hong kong?
    eg:
    USB VAG-COM OBD II KKL 409.1 Diagnostic Cable Interface - eBay Diagnostic Tools, Tools, Car Parts, Accessories, Cars, Bikes, Boats. (end time 09-Oct-10 22:42:53 AEDST)
    p.s. not being a tight arse between a $15 or $30 cable, just confused by the number of different cables!
    Jan 2010
    Noone, how much was your cable and the program you use to diagnose issues related to the car? And can you clear codes with yours?
    Jan 2009
    blankedy
    Software is free.
    Cable cost me $30 from UK from memory.
    I can scan, log, but not clear codes. I have only had 1 or 2 come up, disconnect the battery for a while has always remedied my codes.
