Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Does anyone else find the turbo a bit laggy?
    Nov 2010
    Im just wondering if its just me or whether anyone else find the turbo a bit laggy under 2500 rpm really i guess.
    As the 1.8T is pretty torquey you dont need to rev the nuts off it so i tend to leave it down low in the rev range but then find it can be pretty laggy. Ive got a PD160 intake which should help pick up a bit but im guessing a remap would be the only way to improve it.
    Anyone elses comments or experience?
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
    Jun 2009
    Quote Originally Posted by sssstew View Post
    A quick ecu remap (APR, customcode, superchips/bluefiin, DNAtuning) should fix that problem.
    Unfortuantely the K03 is the earliest spooling turbo available and all the upgraded ones are larger and therefore more laggy.
    Jan 2009
    Go drive a subaru. I really don't find them laggy down low and would rate that as one the strengths (torque as you've suggested), but that's after a subaru, which once it goes through the 2500-3000rpm is great, but under that you wait.
    I'm guessing from your forum name you've had a SSS pulsar, the SR20 engine is those was pretty strong for NA (remembering back 10yrs when they were new and I was a youngster). The turbo cars have a different character which may take a little change in driving style. A few more revs off the line when you want it to go, they are happiest in mid range revs.
    Peregian Beach
    My Polo is chipped admittedly but it pulls like a 16 year old from around 1,900rpm. Actually I rarely rev past 4,750 and I can honestly say that I have never noticed turbo lag in my Polo GTI.
    Aug 2009
    Erm... laggy... stock they push out max torque (and max boost of 9psi) just below 2k rpm :S
    If that is too laggy for you, then turbo cars just aren't for you i'm afraid. Most other turbo 4cyl cars are hitting full boost up around the 2500-3500 zone depending on the car (4000rpm if you have a 2.0L STi).
    After chipping the car it only gets worse, as peak boost now jumps to 18-21psi depending on the tune, and that doesn't hit until 2400-2600rpm in the Polo's
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Dec 2010
    Dalton, New South Wales, Australia
    The std car is very non-laggy!
    ^this
    Jan 2008
    Sunshine Coast
    About all you can do is go for a smaller, quicker to spool but less flow up top turbo, an expensive twin turbo setup, a small supercharger ala twincharge TSI, inject expensive nitrous pre boost or like me watch the development of electrically aided turbo's with great interest! It's a common problem, but as mentioned VW is up there with the least laggy currently available that still produce good power.
    Jan 2011
    Suburbia
    I like the (little) lag there is; makes the 'kick' feel stronger when it does spool up
    The standard 1.8T tune is very soft. Little or no lag. Very linear through the rev range. If you look at a torque curve you will see that VW have really knobbled the standard car.
    APR - High Performance Development for Audi, VW and Porsche Vehicles.
    Jan 2009
    blankedy
    Could be you have a small leak...
