Results 1 to 10 of 16
Thread: does 2.5" and 3" downpipe makes any different?
    boxhill
    does 2.5" or 3" downpipe makes different in power bend?
    i want to have maximum torque on mid range~
    thanks~
    Jan 2012
    Bentleigh East, Melbourne, Vic
    if you want low down torque, then go for 2.5". if you plan on getting a larger turbo, then go 3". just my 2 cents worth
    Polo 9n3 GTI
    boxhill
    yea going for a tune straight after
    boxhill
    does mild steel and stainless steel make much of a different?
    Jan 2009
    blankedy
    For power, I don't believe so. It's about how long it lasts
    From my experience, mild steel systems tend to sound deeper than stainless because of the typically thicker wall piping.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Quote Originally Posted by Sheen View Post
    What does your tuner recommend?
    I reckon you can get away with the smaller one if you have no plans to fit a bigger turbo or wring every last KW from the K03s. Are you buying off the shelf or having one made?
    Are
    Feb 2007
    Brisvegas
    Think testing was done on the K03, 2.5" all the way through was the way to go... 3" gave you no performance gain, other than that impagined in your pants!!
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    When we did all the testing on the 1.8T's (Way back in 2004), it was on the Golf 4 GTI, we ran 2.5", 2.75" & 3" - as above, on a K03, the 3" did nothing up top (turbo out of puff), but lost bottom end torque. 2.5 was nice all the way through, and 2.75" didnt show much benefit over the 3".
    We then tested on K04 1.8T's (specifically the S3) with 2.75" & 3" - 3" showed no more top end, even with the K04 - but lost less down low with the bigger turbo.
    If it was me building it for a K03 street car, I would run 2.5" - if I was going to go K04 in the future I would run 2.75", I wouldn't personally run 3" as you lose too much.
    Problem is most exhaust shops don't carry 2.75" and some don't have 2.5" so they try to sell you 3" piping.
