if you want low down torque, then go for 2.5". if you plan on getting a larger turbo, then go 3". just my 2 cents worth
does 2.5" or 3" downpipe makes different in power bend?
i want to have maximum torque on mid range~
thanks~
Polo 9n3 GTI
You plan to get a tune as well? Won't do much on it's own without one.
yea going for a tune straight after
does mild steel and stainless steel make much of a different?
For power, I don't believe so. It's about how long it lasts
From my experience, mild steel systems tend to sound deeper than stainless because of the typically thicker wall piping.
When we did all the testing on the 1.8T's (Way back in 2004), it was on the Golf 4 GTI, we ran 2.5", 2.75" & 3" - as above, on a K03, the 3" did nothing up top (turbo out of puff), but lost bottom end torque. 2.5 was nice all the way through, and 2.75" didnt show much benefit over the 3".
We then tested on K04 1.8T's (specifically the S3) with 2.75" & 3" - 3" showed no more top end, even with the K04 - but lost less down low with the bigger turbo.
If it was me building it for a K03 street car, I would run 2.5" - if I was going to go K04 in the future I would run 2.75", I wouldn't personally run 3" as you lose too much.
Problem is most exhaust shops don't carry 2.75" and some don't have 2.5" so they try to sell you 3" piping.
