Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: DIY boost leak fix
    DIY boost leak fix
    After the very bumpy TARGA stage last night and fixing a loose sway bar link, it would appear that my car had a boost leak for about 20kms, until it now has lost all boost and will not make any positive numbers at all.
    Forge/SEAT front-mount jobbie, so a lot of plumbing involved.
    As a do-it-yourselfer, where do you start? Any tricks, other than one-by-one?
    Cheap, Fast, Reliable. Choose two.
    Sep 2009
    brisbane
    It's not that big a job, but the bumper probably needs to come off to do it correctly. Personally, I think start at the turbo outlet pipe and work your way to the throttlebody.
    If that doesn't deliver, the PCV and vac system is next.
    I am assuming that you know it's losing a lot of boost 5PSI or more.
    Losing 5?
    It won't make more than 5!
    Cheers fellas
    Jan 2009
    blankedy
    Sure its a leak?
    If you're getting nothing I'd think the loose connection will be very obvious, a flashlight and some time poking around under and down behind the headlights / up through the foglight grills should give you a glimpse.
    Check the actuator rod is still connected to the wastegate flap. Just read your first line again, no boost at all.
    If you had a massive boost leak, I am sure it would stutter like mad, my S3 did when the elbow off the turbo split. As soon as you got to atmospheric pressure it fell over.
    Well it still drives 'okaaaaaay' albeit with no grunt.
    It picks up off the lights, gets to 1400 or whatever revs, builds 2-3psi, then pulls all boost back to vacuum again.
    Very odd. I was under it yesterday but didn't notice anything glaringly obvious as far as loose/split plumbing goes.
    Up on stands tomorrow and have a gander I guess :/
    If you see any boost then the actuator is probably ok, unless the nuts have nearly wound right off? I am really thinking a decent split in a hose, that holds boost, then gives up.
    Wastegate who in the where now? Turbo stuff confuses me greatly.
    I can build a hot mini engine though!
    Feb 2007
    Brisvegas
    Got a boost gauge in the cabin or access to something that can read a code mate?
