Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: DIY boost leak fix
  1. #21
    Quote Originally Posted by Stuwey View Post
    Well, removed, cleaned, checked all plumbing from turbo to throttle body.
    Found one hose had come awry on the steel turbo charge pipe behind the engine cover. Left the battery of while checking everything else, put it back together and we have boost again...
    With a big whistle noise
    Was that the big diameter pipe to the diverter valve.
  2. #22
    No, little one to the right.
    Cheap, Fast, Reliable. Choose two.
  3. #23
    Nov 2012
    Turbo bolts?
    Sent from my GT-I9505 using Tapatalk 4
  4. #24
    Quote Originally Posted by Bullet Fast View Post
    Turbo bolts?
    Maybe
  5. #25
    I'd had enough by the end of yesterday, someone else can have a go now with a fresh set of eyes.
    The exhaust flange has never faulted before, but at this point in time nothing would surprise me.
    Thanks for all your help guys!
  6. #26
    Jan 2009
    blankedy
    The turbo bolts you can feel from above, I've not had any issues with them since I last replaced and used a metal repair material to keep them in.
    Car has to be cold, so much heat from the turbo even if its just been idling.
  7. #27
    Sep 2006
    Tweed Heads
    Hoyhoy.
    If it is loose turbo bolts it would sound like a tractor, so I would say that idea is out.
    Hooroo.
  8. #28
    Fixed - was the join from the hard line to the silicon hose up to the throttle body. Seems mostly OK now, but certainly not the car I had two weeks ago.
    Boost used to peak 19psi, settle around 17 or so - Now it'll peak at 15 and hold maybe 14?
    Man, I need to get educated about these things. Considering the N249 and SAI delete.
    Now that we've got a sensible for the girlfriends daily , I'm getting serious about planning a turbo upgrade/exhaust/gearbox/diff/cage and entering some big stuff.
  9. #29
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Sounds like Stu's getting the disease, poor bugger.
    Hooroo.
  10. #30
    Always had it. This is the car which has remained mostly standard for the longest time. Always had hot cars
    Living in a pertol-headed, circuit-racing family is no help when you're desperately trying to save for a house. Then I go to work at ARB and watch people throw $18k+ at their cars. Gives me the itch!!
