Originally Posted by
sambb
I'm on 5/1/2 degrees of castor at the moment. Where does my 5/1/2 degrees fit against other polos??
Dunno about Polo specs but it's much more than my Pulsar and a far bit less than my 350Z
I would thing you're in a pretty good spot (from a castor point of view) for a FWD
sambb
Yeah it'd be so much easier if we didn't have the stupid strut in hub socket arrangement. My mates clio w172 has the hubs bolt onto a two bolt strut flange. You just put in an eccentric on the top hole and instantly tilt the hub top in against the strut. You get camber without adjusting the SAI at all. We are forced to move SAI when we do camber (top or bottom) which isn't ideal from a geometry standpoint and cost $$ too.
SAI effect is low - you may loose a little steering feel but you're unlikely to notice it due to PWR steering
Eccentrics for strut camber adjustment are not wonderful
It's a technique originally created to fix the alignment of crashed cars - which is why the eccentric bolt is called a crash bolt
Pretty common for eccentrics to move when hammering curbs at the track
I don't use them
sambb
Notso swift - what do you reckon regarding the forces at play down at the ball joint.
As long as you're using VW bolts & nuts it will be fine
Oz high tensile are a bit of a joke (unless you're talking about a class 10 bolt)
