Originally Posted by
seangti
-1.75 degrees of camber is not enough to make a noticeable difference to cornering performance.
Depends
I ran -1.75 degrees on my Skoda Octavia for a few years of daily street driving
This made a huge difference to turn in performance and it did result in some featuring of the inside edge
I could also brake deep into a corner, turning and braking at the same time, it was incredible
(I have supaloy control arms - much like the Audi TT)
But from a motorsport point of view -1.75 is nothing
seangti
It's not enough to balance tyre wear either, you'll still wear the outside of the tyre a lot.
During motorsport (or maybe extremely hard street usage) - yes
For most people, daily motoring, -1.75 deg is way too much negative
My wife's Mazda 3 SP23 had -2 deg negative at the rear,
she wore out the inside edge of the tyres due to excessive negative camber
I've now reduced the rear to -1 deg
seangti
I'm running -3.5 on my left, -2.5 on the right (as I run right handed circuits), and it's my shoulders that show more signs of wear.
Extremely hard driving and motorsport usage will do this to a Macpherson struct FWD
Stiffer springs (maybe stiffer sway bar), tyres with a stiffer side wall and higher tyre pressures will all help
But ultimately, under sever conditions, there is no substitute for negative camber
I'm running -5 deg on the front of a Nissan Pulsar (2L NA FWD) for track only usage
