Steady guys. Don't wanna have to throw a bucket of cold water over you.
Dave
Back to thread...This thread should help you out.
http://www.vwwatercooled.org.au/newf...ight=Forge+BOV
Don't want to start a new thread. Can someone tell me how my car will benefit from a APR R1 diverter valve, in simple mans terms - what does it do?
I have APR V2 software, SEAT air hose etc...
Thanks
The APR valve has a bit more tension on the spring and is all metal... With a remap, under the increased intake pressures, the factory plastic Bosch valve can fail or sometimes leak slightly...
I am fairly sure the 911 turbo's run the same DV as the 1.8t so that will give you an indication of the quality of the OEM Bosch item. IMHO there are better ways to spend $200, only replace your DV if it leaks/breaks
I am doing full atmo, no code nothing...
Car is chipped but not as powerful as other member described, maybe i m in the chipped limp mode?
Has any one got an OEM diverter valve / DV to suit a Polo GTI that they don't need - I am after one as I damaged mine (snapped the vacuum line off the top)...
If you do please let me know and how much your after!
jonathanmayes@hotmail.com or mobile 0420 902 784
JCM
