Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Diverter Valve
  1. #21
    Sep 2006
    Brisvegas
    Thats cool just thought i would clarify.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
  2. #22
    Feb 2007
    Brisvegas
    I have had a little bit of experience with BOSCH valves runinng on 180's with upto 18psi... Never seen any problems. They are designed for a stock application but are farily well built (just because they are not shiny Aluminium doesn't mean they are poo) and as long as they are used within those limits you should have trouble free motoring... As Gavin said a lot of the time the diaphram splits or seat wears causing leakage... Mots of the time you will notice if your BOV has gone as it will start to leak boost causing preformance loss...
    If it does seal shut - it will start to get laggy as the air returning from the throttle body will cause the exhaust wheel to spin in the reverse direction which is definatly not good. Also notice some cars that sort of pulse with BOV discharge - this is due to compressor surging and is also not good. If you have this sounds look at it asap...
    The reson most change BOV is becuase the stock spring preload can no longer hold the diaphram shut under load and the BOV is forced open under the boost pressure in the piping - but i think we are talking upwards big boost here
    Don't get me wrong if you want the sound then its not a waste of money... to me it is thou... but if you get one make sure it is a dual stage with plumb back and trumpet... Took me ages to find that problem on a 180 when it kept stalling at the lights.... I used to have to sit @ 2000rpm... everyone thought I was up for a TGP
  3. #23
    We use the stock Bosch one on our Polo GTI (~18PSI) and its as new after 13,000km's
    On our TT we run ~26 - 28 PSI and a stock new Bosch DV, 10,000km's + still like new. The action of the diaphram types is quicker, even if they are not as bulletproof as an alloy unit!
  4. #24
    Oct 2006
    funnily enough ive had 2 go on me .. strangely enough!
    as mentioned, stock is best but lasting it all depends i guess. doesnt hold driveshafts together tho
  5. #25
    Dec 2006
    Gold Coast
    Well.....
    I thought id get one and try it too see what happens.
    It works well. Makes a not so loud noise. But does make a noise. Which is what i was after. For anyone thats wants to pay for one. 309 is how much they are. I may or may not have payed.
    If i ever get sick of it. I can just chuck the old one straight back on. Or turn this to plumback only.
    Pics will take forever to load on 64k
    http://images.cainer.net//uploads/Picture204.jpg
    http://images.cainer.net//uploads/Picture001.jpg
  6. #26
    Mar 2007
    Newcastle, New south wales
    My brother is pestering me to buy one of these turbosmart thingies.
    because my forge 007 whatever doesnt make anymore noise than standard.
    With the turbosmart, what kind of a noise does it make, does it give a little flutter? or is it just the normal pshhh?
  7. #27
    Dec 2006
    Gold Coast
    it gives more of a ccccht noise. Not a pssscht noise.
    I wouldnt really recommend it for the wank factor. But mine on the lowest setting.
  8. #28
    Oct 2006
    plus the more boost you run, louder it'll be ..
    the gfb ones are slightly louder (the normal plum back) compared to the 007.
    the new forge dv-bov's are about $300-350 tho, cheaeper then the gfb stealth fx at $450+!
  9. #29
    Oct 2006
    Judging from the first pic Kai, it mon't make much noise because it's venting straight under the engine cover.
    Atleast the plugs are staying awake.
  10. #30
    Dec 2006
    Gold Coast
    Quote Originally Posted by Flaps View Post
    That was just to show it can easily be hidden
