Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: disabling ESP
  1. #41
    Jan 2009
    Sam, I brake hard with right, as I come back across on the throttle the left foot comes across to pick-up brake pressure. It's come relatively easily from PS3.
    Daily: 2010 VW Jetta Highline
  2. #42
    nsw
    my home track is basically all second gear with no clutch action other than off the start line. Speaking to some of the good guys they say they left foot brake the entire course - left foot only. I guess on a track with no gearchanges that would be ideal to really get on top of it without the extra complication to worry about. In that vid he's using it to tuck the nose in (which is all I ever did in the past with my escort) but you can really see him using it to help the power down on exit which is what will be new to me. I remember the guys at Bathurst talking about it for the entry up griffins bend where you need to wash off a touch of speed before tipping it in saying you'd loose too much time if you broke especially in a turbo where you drop all your boost, too risky to lift as it'll unsettle the rear of the car but that left foot braking was the way to go. For me I think i'll try and nail it on my second gear track before I try the high stakes stuff that's for sure.
    Thanks for the tip. Down the track a LFB tune would be ideal. Practicing on the street even out at night or something is a bit dodgy without brake lights but it'll get me started, so thanks for the tip. I'll just have to try to suss if its killed ESP fully or if its only TC that's out of commission.
  3. #43
    nsw
    talking with a friend of mine we had a bit of an idea. I think the brake pedal plug is a dual contact 4 wire. You'd only need to isolate which pair is the input for the ESP/brake circuit and break into that with a remote dash mounted switch, leaving the plug complete with its brake lights contact alone. That way you could have a switch operated ESP/TC cut that allows left foot braking but retain your brake lights so you could drive it on the circuit or street. I'll have a squiz tomorrow.
  4. #44
    May 2016
    Greece
    delete
  5. #45
    nsw
    No I haven't followed up on having a cabin switch to activate/de activate the brake switch. I have a foggy memory of looking at the plug and it only has 2 wires connected I think. From memory it doesn't have open or closed circuit resistances on the switch either so a normal on/off switch would work. Its simple enough to get to the plug anyway - you can get at while seated once you work out what to feel for. It doesn't deactivate the ESP but does with the TC and allows you to left foot brake.
    If you want ESP totally dead you need to take out the ABS fuse. You'll loose your speedo and any display fuel economy/km's data. I couldn't feel any scary rear brake bias issues in a few swerving crash stops but you'd really have to be on a track to test that out at the limit really. It really makes you see how intrusive the ESP can be. Near me there's a sweeping left downhill on camber corner that you trail brake through because at the end of it there's a hairpin and there's a similar corner on my home track. In both instances every single time I go through there (with the TC off) you can feel the ESP pulsing away gently underfoot - the car is in no way out of shape or about to be but the ESP system is crying "save him!". Even after the ESP has initiated it takes forever to get over itself and is still intruding after you've straightened up and are transitioning into the next right hand corner. With the ABS fuse out and in the same situation you can't feel the ESP intrude and you are still far from crashing like the computer thought you were going to earlier. Its just that in the grander scheme of things on the track for me I have a lot more confidence at the limit knowing the ABS is in play when there are no run off areas and lots to hit - I mean if I had an off i'll still hit something, just not as hard hopefully! So in the balance of things I still run with the ABS fuse in and the ESP rattling away, but with the TC/ ESP button off because the throttle cut is terrible otherwise.
  6. #46
    May 2016
    Greece
    delete
  7. #47
    nsw
    I remember now that I did unplug the steering angle sensor. It resulted in mono weight steering. I think the variable assistance is run off the steering angle. It felt fine driving it at speed but was impossibly heavy at parking speeds. Definitely not recommending that one. Apparently the 9N3 gti has no yaw sensor and I certainly couldn't find one. It must be a combination of ABS wheel sensors, steering angle sensor and brake switch.
  8. #48
    May 2016
    Greece
    delete
  9. #49
    May 2016
    Greece
    delete
  10. #50
    nsw
    not sure. i'll have a look next time I log.
