I was modifying the brake settings (in the VCDS brake module) - not the ESP settings
ESP can use both ABS and throttle to aid managing the car
The only way to get totally on top of ESP is via a ECU flash (which is fairly expensive)
I must admit I turned ESP off at the track but only because I was running semi slicks and the car thought I was in trouble
