Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: disabling ESP
sambb disabling ESP 01-09-2015, 05:01 PM
h100vw When you go to find out Sam,... 01-09-2015, 06:08 PM
rgvlee I'm not game enough to turn... 01-09-2015, 06:11 PM
seangti I turn off TC when doing... 01-09-2015, 09:04 PM
sambb TBH its a struggle to make... 01-09-2015, 10:31 PM
seangti If doing motorkhana or hill... 02-09-2015, 10:47 AM
sambb Sean, is that definitely... 02-09-2015, 11:17 AM
seangti It came from my mechanic when... 02-09-2015, 11:24 AM
ben22j I've had my ABS fuse... 02-09-2015, 08:16 PM
sambb tell me more. I've read... 02-09-2015, 08:57 PM
ben22j No I've never had the rears... 03-09-2015, 10:59 AM
sambb and can you left foot brake... 03-09-2015, 02:14 PM
ben22j Dunno, I'm not really Colin... 03-09-2015, 05:34 PM
sambb ha ha neither am I. I havent... 03-09-2015, 06:13 PM
Stuwey If you touch the brake first,... 04-09-2015, 08:03 AM
sambb just a follow up. There are... 13-10-2015, 08:30 PM
sambb well I went for a very... 14-10-2015, 04:03 PM
sambb another observation. I put... 17-10-2015, 09:30 AM
sambb well went for a drive to... 17-10-2015, 03:46 PM
sambb Martin in the "rear brake... 25-10-2015, 08:23 PM
h100vw There might be some coding... 25-10-2015, 10:30 PM
Martin I was modifying the brake... 25-10-2015, 11:08 PM
sambb I found this quote in a... 15-11-2015, 01:28 PM
h100vw I am pretty much 100% there's... 15-11-2015, 01:43 PM
sambb Ok I suspected that. I read... 15-11-2015, 01:55 PM
h100vw VCDS and it's on the page... 15-11-2015, 02:11 PM
sambb Just a follow up to all this.... 16-05-2016, 12:52 PM
kaanage Does anyone know which fuse... 19-05-2016, 05:08 PM
sambb I'll check tomorrow. The one... 19-05-2016, 07:12 PM
Blue9N3 I pulled the abs fuse some... 19-05-2016, 07:15 PM
kaanage The manual!! I always forget... 20-05-2016, 09:17 AM
sambb I hope you give it a go... 20-05-2016, 10:23 AM
kaanage Since the PoD is so... 20-05-2016, 05:43 PM
sambb Yeah the ABS fuse is fuse 23... 21-05-2016, 02:23 AM
sakisvag So are there any news on this... 22-05-2016, 03:49 AM
hardy_bm Yes it will and you will buy... 22-05-2016, 10:15 AM
sakisvag Not the case if you have... 22-05-2016, 09:54 PM
sambb bit of an update to this... 10-08-2016, 11:49 AM
seangti Wow, I got something right. ... 10-08-2016, 05:19 PM
sambb I'm not good enough to brake... 10-08-2016, 07:44 PM
seangti Sam, I brake hard with right,... 10-08-2016, 08:12 PM
sambb my home track is basically... 10-08-2016, 08:46 PM
sambb talking with a friend of mine... 12-08-2016, 07:43 PM
sakisvag delete 12-09-2016, 01:13 AM
sambb No I haven't followed up on... 12-09-2016, 01:51 AM
sakisvag delete 12-09-2016, 03:19 AM
sambb I remember now that I did... 12-09-2016, 03:39 AM
sakisvag delete 17-09-2016, 05:42 AM
sakisvag delete 18-09-2016, 03:14 AM
sambb not sure. i'll have a look... 18-09-2016, 10:30 AM
sakisvag delete 25-09-2016, 09:07 AM
sambb yep you're right - mine is an... 25-09-2016, 08:00 PM
sakisvag delete 25-09-2016, 08:39 PM
sambb previously in this thread... 01-01-2017, 10:54 AM
seangti lol, love your perseverance.... 01-01-2017, 06:36 PM
sambb ha ha Yeah baby sitting an... 01-01-2017, 07:45 PM
seangti You probably need to get a... 03-01-2017, 09:20 AM
    May 2016
    Greece
    delete
    nsw
    yep you're right - mine is an 8.0. It may just have a sensor then. Tomorrow night I go hunting for that little sucker. If it is in there the next step will be how to fool the ecu into thinking the car is is experiencing no G's. you're a legend!
    May 2016
    Greece
    delete
    nsw
    previously in this thread after a tip off from Sean I'd found that if you unplug the brake pedal switch, you can left foot brake without the throttle cut coming in. Problem was it also meant your brake lights stopped working.
    The 4 pin plug has two 12 v feeds, i figured one for the brake lights and one for the ESP system. Thinking the other two wires were the switched wires I cut them one by one and tested. I was hoping to just knock out the circuit that would allow me to left foot brake but retain the brake lights, but it wasn't to be. Seems the only way to get left foot braking is to unlug the brake switch which kills your brake lights and makes it street illegal.
    Jan 2009
    lol, love your perseverance. I just emailed my tuner and told him what I wanted and he sent back a new file to load. 3mins later and I'm a happy camper.
    I'd have thought for your application (hill climbs and time trials), brake lights wouldn't be needed.
    Daily: 2010 VW Jetta Highline
    nsw
    ha ha Yeah baby sitting an empty factory like a Homer Simpson on new years day will make you look for things to do. Everything is safely soldered back to factory now.
    Funnily enough at the hillclimbs even though I'm in road reg class they have never been checked once. But then at the rallysprint scrutineering they did check them even though there was no road registered class. I could still do my runs with it unplugged though - no one would notice. I really was hoping this would work so I can practice LFB everywhere I go so that its instinctive on the track. At the hillclimbs you get so little actual seat time and its 10/10ths on tracks that are pretty friggin dangerous if you bugger up that I wouldn't really want to be experimenting on the go.
    Jan 2009
    You probably need to get a track to practise it, I use LFB to balance the car before tiping into faster corners (get a little weight transfer over the front on tip in), to tighten my line in lower speed corners, or on exit to lock up the diff if it's spinning too much. I'd be surprised if there's many places on the street you can truly experience the feel with minimal risk to yourself or others.
