Results 11 to 20 of 23
Thread: Differential ring gear identification: 113mm or 114mm?
    Feb 2007
    Brisvegas
    It was actually Guys little track car http://www.vwwatercooled.org.au/foru...oids-2786.html
    Sep 2006
    Tweed Heads
    Quote Originally Posted by VWindahouse View Post
    Hoyhoy.
    It was Guys little track car, but that diff ended up in the Little Blue Girl for a while.
    Then luckily enough I got Guy to order the SQS clutch diff because SQS didn't know that there were two different ring gears, otherwise I would of had the wrong one.
    It cost me extra for them to make it.
    Hooroo.
    Apr 2006
    VW Race HQ - Sydney
    Ive gone through this issue many times and ended up just keeping both in stock . Vin makes no difference as well .
    Bug_racer supports the rebellion of the euro revolution
    Aug 2007
    Quote Originally Posted by Bug_racer View Post
    Yep cant disagree, ive pretty much talked myself into that with the fact that the 02r from the day it was released the diff number is the same meaning they can fit any ring gear, whatever batch they have at the time which sux for us. Each car gets a BOM ( bill of materials) when built and you could have a diff from any plant really.
    Jmac
    Alba European
    May 2011
    Perth
    Did you still need a vin. Also to the uneducated what does this all mean? I don't mind googling definitions of parts and their locations im just finding it hard to understand.
    Jan 2009
    blankedy
    Means you can't easily work out which one to get without opening it all up to measure. Ridiculous, but what can we do...
    Aug 2007
    Quote Originally Posted by blitDz View Post
    Sorry mate, here is a pic of the ring gear and measurement we are all talking about.
    Jmac
    Alba European
    Bit of a thread revival.
    Is there any consensus on the best place to buy a Wavetrac?
    Also wondering if there's any differences other than the inner diameter between the 113 and 114mm ring gear?
    Why I ask is I was thinking if you got the 114mm TBD and then worst case if you have a 113mm ring gear just take it over to a machine shop, half an hour later you've got a 114mm ring gear. Might be easier than faffing about ordering 2 diffs, returning one, etc.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Oct 2010
    Melbourne, VIC
    It is seriously NOT a place you want to be elongating holes or getting extra ones drilled.
    Chris Preen was looking for people interested in a group buy but it was a while back.
    Resident grumpy old fart
    Aug 2012
    Sydney NSW
    Quote Originally Posted by spraycanmansam View Post
    There doesn't seem to much interest for a group buy for the wavetrac or maybe it's just too hard. My suggestion is to find a local supplier thats stocks both sizes. For Sydney people Seb at Euro Automotive.
    Try this page for a start:
    Wavetrac® Differentials - Dealers
