Nice one mate, thanks! Hopefully we can get to the bottom of this.
In deference to keeping VWindahouse's Little Red Devil thread on track, here is a place to try and garner information about our differentials in order to know what LSD or TBD variant is needed.
Here's Jmac's insight into the situation (along with some info I found)
Resident grumpy old fart
I'll be trying to find my transmission number as well as the VIN tomorrow so I can send it to Jimmy
I really would love to get a TBD as my PoD needs all the help it can get to put what power it has to the ground when at the track![]()
How when where what and how can I be of assistance with getting information for you guys. Also looking at diffs in future.
If you can get your VIN number to Jimmy mate that would be a big help. What year was your Polo manufactured out of interest?
Ok guys ive measured the one i have here, its 113mm ID and the Gearbox is HWY. Ill check the OEM diff number now and then see what if any difference with another of the 2 codes we have. Now this is all good and well but the only thing bothering me now is the fact that you cant get a ring gear seperate from VW, meaning if you had a faulty diff or chipped tooth etc they could supply the 114 or 113 really as it all comes as one unit, make sense. Im hoping im worng and there is a sequence to what they fit to what. Best to see what other gearbox codes have to see if thats conclusive.
ps cheers for starting the thread
Jmac
Alba European
I reckon the transmission code wouldn't hurt either - you may need all the info we can give you, Jimmy.
I don't know if VW have any of the 114mm diffs left, though, if you had to order a new one, since they changed the design to allow more room for stronger rivets in the later diffs. The confusing changeover may be due to VW starting to produce the newer diff with the smaller ring gear while still having stocks of the older diffs at the various plants that assembled cars with 02J tranmissions.
With what i have guys i see like this, i have a HWY gearbox with a 113mm ring gear, ive checked this and used Anthonys vin as an example as hius box is HWY too. The OEM part number is 02J409021BE and can be supplied for any of the 3 codes im afraid so if its true that there is 2 being 113 and 114mm it means they could fit anything as they come complete diff with ring gear all riveted. Seeing as its an 02J Diff ive checked all that had 62/17 teeth ring gears and it seems post 06 only had 113mm. Seeing as this is a drama has anyone actually came across a 114mm in a 02R, really keen to hear as that would cement my thoughts for sure, if yes then we are right back to the beginning with the only way of knowing being a strip done and measure. You could be right about different plants etc thats maybe why we see it, in that case if it is then we are stuffed.
Jmac
Alba European
Hey mate, I don't suppose you know the month in 06 the 113mm started coming out? I remember Guy had an earlier model than mine and he had to do some machining when we put his peloquin in. Not sure if that's relevant?
Was that Eddy's little blue girl? I know he had a Peloquin in it before the SQS Salisbury LSD.
In another thread about a Peloquin, someone mentioned machining the ring gear after unrivetting it so that the mating surface was dead flat because the Peloquin, Wavetrac and Quaife are made of much stronger steel than the original. This means they won't deform to mate to the ring gear the way that the original can (talking about tiny amounts here but the resulting gap can cause the bolts to suffer more shock loading => failure and destroyed diff & housing).
It may well have been Jimmy who mentioned this.
