Results 1 to 4 of 4
Thread: Difference between Polo GTI and non-GTI shocks / struts
    May 2017
    Sunshine Coast, QLD
    Hi,
    I have a set of Koni FSD struts and shocks that suit a Polo 4 9N from 11.2001 to 06.2009 (Koni part number 2100-4041).
    According to Koni , it excludes the 'Fun', Cross Polo & GTI.
    I'm just wondering if anyone knows what the difference is between the standard Polo and Polo GTI suspension (i.e. why these wouldn't fit a GTI?)
    nsw
    My best guess would be that it has to do with the weight over axle ratings. I know that Polo Gti suspension is 15mm lower than normal 9N3 suspension eg TDi etc. But the kits are still compatible due to their weight over axle ratings being the same. I think that's why the exclusions exist for the non turbo Polo's - they don't have the TUV certificate that rates them at I think its 960kg:840kg F:R weight over axle. Eg your static ride heights might be all over the shop because of mismatched load ratings with the front springs unable to support the extra front end weight. I'd say the damper valving and stroke would be incompatible too.
    May 2017
    Sunshine Coast, QLD
    Hey sambb - great answer and thanks for the response. That makes perfect sense. I wonder if the overall length is the same, or if the strut perch height is different between the turbo and non-turbo models? Unfortunately I don't have a turbo strut to compare.
    nsw
    yeah its possible the strut perch is at a different height to clear different rolling diameters of the tyre/rim combos too.
