My brother did the wiring for me but when i see him next ill ask him about the wiring of the dimmer.
Here are some pics of them installed hopefully these make it easier for u.
(1) Here is the rubber plug in the firewall (front passenger footwell) u can run your cables through for the sensors. You are going to have to cut the connector plugs of the defi sensor cables and solder them back on otherwise u wont be able to fit them through the hole.
(2) I installed my gauges in the tray on top of the dash, this is easily removed with a couple of clips on the side of the tray, get rid of the rubber lining in the tray and drill a hole in it for the rest of the cables. As u probably already know u only need the one power cable and sensor cable as any extra gauges are hooked up by a daisy chain. Once u have removed the tray u will see the pipes for the vents there is plenty of room to run ur cables down the side of the vents to the footwell where u will have ur hole in the firewall.
(3)As for the controller this was probably the most time consuming to install in the pic below u can see i have mounted it under the climate switches, if ur going to mount it here you need to peel back the rubber mat just above the ash tray and undo the 2 screws pull back that plastic panel and basically shove the cables through. you will notice there is barely any room there is a black box which gets in the way but u can pull ur cables through from the drivers side footwell from here u need to hook it up to a constant power and a accesories power and the dimmer switch so when u turn ur lights on ur defi gauges will dim in accordance with ur instrument lights.
Hopefully this will make ur install easier s1831559 (Next Page has them installed in tray)
