I would love to upgrade to slotted rotors, continue using the standard calipers and upgrade the brake pads and fluid.
Dont think they offer anything for the polo though? nothing in the catalogue
Yes
No
Hey guys Just been looking at the DBA 4000 series slotted rotors for my car.
Does anyone have any opinions on them.
Have heard good and bad things.
Another option would be the ATE power rotor but would like to go with an Australian company.
http://www.dba.com.au/2006/catalogue_aust.asp
They make them in the 312mm so will work with the bigger brakes on the car.
Any real gains going with a new rotor?
I am almost 100% sure the MK4 GTI rotors are the same ill track it down for you and find out.
Rob i voted yes, With the amount of track work you do im sure you will find it better. I was thinking the same as mitch. Maybe slotted and dimpled though???
People whom I’ve spoken to who rally & race and know of these things say that slotted rotors are brilliant at drastically shortening the life of your pads and little else.
If they do that then the pad is getting more bite on the rotor.
The purpose of the slots is to remove the surface of your brake pads every time you apply them in an effort to remove glazed materials. Maybe helpful if you are always glazing your pads (I can’t imagine you are with your rotor upgrade) or if your car spends 99% of its life at 10/10ths on a race track.
If you like the "look" and have the money, why no? DBA is a good local brand with good support if you have problems.
But you'll probably notice no difference -- perhaps even worse when cold -- in braking performance for 99% of your driving.
What pads/fluid are you using? In terms of performance improvement over stock, that's where you'll probably find the greatest immediate and significant gains.
Ok this is he sales speel for MRT Discs. found here MRT. I know its about there WRX but the principle still stands. THIS IS ONLY FOR REFERENCE OF THE BENEFITS OF DRILLED AND SLOTTED ROTORS I AM NOT RECOMMENDING MRT.
This is off DBA Themselves DBAOn the slotted rotors, directional slots have been milled into the rotor surface.
These slots have two benefits. Firstly, they lightly scrape the brake pad during use, preventing glazing of the pads, keeping performance at 100%. Secondly, they aid in dispersion of dirt the gasses emitted by the pads under hard use ("out-gassing"), keeping the pads in constant contact with the rotors.
For ultimate performance and looks MRT Performance recommends the slotted and drilled rotor.
These top of the line rotors have been designed, utilising advanced computer modelling. As well as the slotting described above, the rotor is also cross-drilled (see picture). The carefully designed holes (one per vane on ventilated front discs) aid cooling of the rotor, as well as dispersion of water, dirt and out-gassing.
Now personally i wouldnt get drilled rotors, but i know you can get dimpled ones which i will look at when the time is right.Why use drilled or slotted discs?
Drilling or slotting discs aids the disc in several ways:
The edges of the slots or holes continuously clean and refresh the pad surface as well as providing increased brake "bite". Additionally, they prevent gasses from collecting between the pad and disc interface.
The disc is lightened, thereby decreasing its rotational inertia.
Improved ventilation increases the disc's ability to shed heat, resulting in cooler operating temperatures
