Results 1 to 6 of 6
Thread: Dashlights & Cluster Lights STOPPED Working
    Mar 2009
    Caroline Springs, VICTORIA
    Hi,
    I have a VW Polo 1.9ltr TDI 2007 model.
    Today my lights stopped working on the dash (heater controls), door panels and on the cluster. The AC and recycle air lights work (orange) only. So now when driving in dark I can not see anything.
    Has anybody had the same problem or a fix it solution?
    Yes...I have checked every single fuse in the fuse box (3 times) and not one is burnt out!!!
    As the car is still under warranty should i give VW a call and explain the problem and will this be under warranty?
    Any help or comments would be much appreciated.
    Jan 2009
    sunshine coast
    dont quote me , but im pretty sure it would be covered under waranty. ring the vw car yard you got it from and ask them for sure.
    Dec 2006
    Gold Coast
    if youve put in an aftermarket stereo they will try get out of it. But if not. It will be covered.
    Aug 2007
    Light switch springs to mind there mate. The feed for the dash illum comes from this switch (Grey/blue wire). Feeds the dimmer switch. If the feed is there then it could be the reostat in the dimmer.
    Jmac
    Alba European
    Mar 2009
    Quote Originally Posted by Jmac View Post
    Jmac
    GOT IT WORKING!!!!!
    Pulled out the light switch and plug and then placed back in and everything is back to normal. Most certainly a loose contact however once you mentioned light switch it was probably the only things i haven't tried and it worked.
    New to the Forum and appreciate the help...Thanks.
    Jan 2009
    sunshine coast
    another save from jmac
