dont quote me , but im pretty sure it would be covered under waranty. ring the vw car yard you got it from and ask them for sure.
Hi,
I have a VW Polo 1.9ltr TDI 2007 model.
Today my lights stopped working on the dash (heater controls), door panels and on the cluster. The AC and recycle air lights work (orange) only. So now when driving in dark I can not see anything.
Has anybody had the same problem or a fix it solution?
Yes...I have checked every single fuse in the fuse box (3 times) and not one is burnt out!!!
As the car is still under warranty should i give VW a call and explain the problem and will this be under warranty?
Any help or comments would be much appreciated.
if youve put in an aftermarket stereo they will try get out of it. But if not. It will be covered.
Light switch springs to mind there mate. The feed for the dash illum comes from this switch (Grey/blue wire). Feeds the dimmer switch. If the feed is there then it could be the reostat in the dimmer.
Jmac
Alba European
GOT IT WORKING!!!!!
Pulled out the light switch and plug and then placed back in and everything is back to normal. Most certainly a loose contact however once you mentioned light switch it was probably the only things i haven't tried and it worked.
New to the Forum and appreciate the help...Thanks.
another save from jmac
