Originally Posted by
noone
Is it called the outer CV bush?
Am i likely to run into issues if this is not fixed pretty quick?
It is called a CV joint. It has precision ground balls & accurate machining in the inside.
It needs to be fixed ASAP before any water or dust gets inside. It would be like removing the seals on a sealed ball bearing, it wouldn't last very long.
Numerous Mk1 Golf diesels
