Vw cannot detect the remap never from any of the equipment i used there unless im missing something. Remember the remap is emulating the original program guys, so how can it be detected. Lets face it you wnat to switch it off to stop the hoons cowboying in your hard earnt.
Alba European
FOR SALE
"VW GTI" QLD Prestige Plate
If you read and write any eeprom including the dash cluster you will get this prompt, because you are overwriting it , there is a warning prompt. Came across it heaps. 5051 software may have changed since i was in dealerland, when i was there i dont remember it ever being the case , would like to know more if it is.
JMac
Alba European
VW dealers can only tell if the ECU has been modded by looking at the reflash counter. This is the only way for a dealer to tell without sending the whole ECU in for inspection by the factory. Most ECU tuning companies have not been completely successful in not resetting the flash counter so many of the ECU chips out there are very detectable to VW.
APR does not reset the flash counter, so irrespective of how many times you change the map it stays at where the factory had it. This is why the dealers (who know how to change APR maps) have gotton into the habit of fiddling with the cruisecontrol buttons in the appropriate manner to see if they can detect an APR chip. I have seen them do this ..... !!!!
Which is also why mine is security code locked ....
2015 White German SUV
2013 White German hatch
2011 Silver French hot hatch
2008 TR Golf GT TDI DSG
Ah well things have changed then. Ive only been away from Porsche for 12mnths. The flash counter wasnt reset , and i seen many Turbos come through and i knew they were flashed same goes for Cayenne. Undetectable then. Tunes werent all done by APR either. Anyway you learn something new everyday. Glad we do otherwise it would all get a bit boring.
Alba European
