Just for the record, what has been described isn't a double declutch - because the clutch is only disengaged once.
I've always hit the clutch moments before actually backing off the accelerator (rather than the other way around), which results in a little bit of a 'blip' or 'overrun' while I change gears.
I've said it before though - the Polo clutch pedal has to be basically on the floor before it disengages fully. If you try to rush a shift before your foot is pinned to the firewall, you'll get a crunch.
