Results 1 to 5 of 5
Thread: Cruise not working.
    Sep 2009
    Mernda, Vic
    Cruise not working.
    Hey guys. Help please.
    One of my brake lights went out today so i pulled it out and drove down to repco (60kms away).
    On the way EPC and traction lights came on. And cruise just stopped working.
    Put the globe in lights went away. Still no cruise.
    I checked the brake switch (accel and brake ) and fuel cuts out.
    Disconnected battery for and hour.
    Still no cruise.. Ideas??
    Mark
    Oct 2009
    new south wales
    I had a similar series of problems on an older car, came down to a couple of fuses. Easy to check, open the drivers door and open up side panel on dash (if not, on the other side, can't remember). There's a special tool to help remove and replace, plus a couple of spare fuses. Take care when looking, as one of my troublesome fuses blew and then rejoined with the tiniest of connections. Hope your solution is a simple as mine.
    Jul 2010
    There may be a fault code left in the system that will disable the cruise as the cruise control is linked to the brakes.
    If all is ok, it should clear itself after driving a bit more (fault code changes to intermittent) and cruise will return on the next start up. Had a similar issue with my Passat, brake fault and cruise.
    If not then get a scan for the code.
    2008 Passat 3.2 Wagon |
    2002 A3 1.8T | APR Stage 1| APR Downpipe | APR dogbone | Diesel Geek Shifter | TT pedals | Forge DV | Saikou Michi OCC | NewSouth Boost Gauge | AVUS Rims | Whiteline Rear Swaybar & ALK | N75J | BMC CDA | APR TIP & TB Hose |
    Sep 2009
    Mernda, Vic
    Thanks guys, I will check the fuses tomorrow. Otherwise my mates got a scanner so ill go there and check the trouble codes.
    Its under warranty, but hate booking my car in and waiting a day while VW check things i can do myself.
    Mark
    Aug 2007
    brake pedal switch , upgrade to the upgraded version
    Jmac
    Alba European
