Results 1 to 5 of 5
Thread: Cruise control stopped working
    Dec 2014
    Canberra
    My cruise control won't work.
    the stalk seems to work fine because the green cruise control light comes on but pressing the "set" button just won't do anything.
    2008 volkswagen polo gti
    You need someone with VCDS to look at that. Could be the stalk or a couple of other things. Be very easy to prove what it is with the cable.
    Mar 2013
    Brisbane QLD
    Usually brake light switch or if manual clutch switch issue
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Quote Originally Posted by vdubmotorworx View Post
    They are all manual
    Mar 2013
    Brisbane QLD
    There you go then...try disconnecting the clutch switch and bridge the 2 wires and retest. Usually doesnt log a fault at all on vcds as the system just sees the clutch switch depressed instead of seeing it open circuit. Clutch down = cruise off.....switch open circuit = cruise off
