Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Cracked brake booster line cause boost leaks??
  1. #21
    Thanks I just did A 3rd gear pull from 1500rpm up hill holding 18psi but vac is fine now at -20 my n75 should arrive by friday I hope that's the problem.
  2. #22
    I doubt you will find a drama with the N75. In my experience, they work or not, nowhere in between.
  3. #23
    Jan 2015
    New Zealand
    Hopefully have my own boost leak sorted soon. Maybe take a look at this to see if it's of any help... Missing when cold
    Good luck!
  4. #24
    Lol well I'm not that excited about my n75 arriving then after knowing that.
    Thanks for the link & I can't wait to pressure test my car and good luck with your leak mate
  5. #25
    I'm doing a pressure test i can hear a massive leak but can't find it but I did find a few little spots. What's this part called please anyone in 2nd pic below
    Attached Thumbnails Attached Thumbnails Cracked brake booster line cause boost leaks??-20200213_143302-jpg   Cracked brake booster line cause boost leaks??-20200213_152522-jpg
  6. #26
    All sorted for the main leak it was the TIP clamp to the turbo it was loose and just tested it at 40psi of pressure and no leaks ��
  7. #27
    Quote Originally Posted by Nikogti View Post
    That's the suction jet pump
  8. #28
    Thanks heaps mate I just ordered it & that part was bubbling up heaps under pressure
