Results 1 to 9 of 9
Thread: coolant warning light flashing?
    Sep 2008
    Perth, Roleystone
    Started the car this morning, all fine for about 2 mins then the coolant warning light starts flashing. I turn the car off and check the coolant and under the car...No coolant missing at all. turned the car back on and no light!
    Read the manual and it tells you not to drive the car if the light comes on and the coolant is fine...Now the manual doesnt say anything about the light flashing.
    So anyone have any ideas on this?
    Thanks in advance.
    Matty
    BMW E36 M3 3.0L LTW - SZYBKI
    VW Up! 1.0L - WGN WERKS
    Mar 2007
    Gold Coast
    Quote Originally Posted by polo_spec_d View Post
    Thanks in advance.
    Matty
    Is it below the line at all in the reservoir? I know my coolant light has come on when it's just down a tiny bit. Simple solution is to fill it a bit above the line.
    Sep 2008
    Perth, Roleystone
    Its mid tank, I have read the other threads on here about the light coming on but nothing on the light flashing.
    Aug 2007
    Perth WA
    Is that when it's warm or cold? Mine sits above the Max line when it's cold.
    '04 BMP MkIV R32 #144
    search getnew
    Mar 2007
    Gold Coast
    I'm fairly sure it flashed when it came on, and was accompanied by lots of 'ding' noises from memory
    Canberra
    Was there any dark stuff in the coolant bottle ? When the oil cooler in my Transporter carked it allowed oil to get into the coolant - the coolant sensor freaked out and I got the boing, boing noises, plus the scary stop engine, check coolant, imminent danger of nuclear meltdown etc etc messages. It doesn't take much oil to confuse the coolant sensor.
    Also it was a PITA to get ALL the oil out of the coolant - needed lots of strenuous highway driving to get the engine hot enough to finally shift it all to the coolant bottle (the VAG flushing agent is obviously not very effective).
    in my old polo when my coolant level dipped below minimum it flashed at me.
    Just top up your coolant bro
    Nov 2008
    Killara Sydney
    Coolant level
    We always topped up bottle to the drip symbol on the side of the bottle, if your levels ok could be a dodgy sensor. Have replaced several under warranty. Cheers'
    Joe Chu
    Sep 2008
    Perth, Roleystone
    Yeah you are right Joe Chu, it was a dodgy sensor, all done under warranty
