Results 1 to 10 of 18
Thread: coolant warning light
    Dec 2006
    sydney
    hey guys ...my coolant warning light came on last nite and stayed on....i checked the level and its right on minimum do i go out and buy coolant or topp it up with water?
    thanx
    Peregian Beach
    Topping it up once with water would be OK.
    May 2007
    Read your owners manual!
    It will suggest a small amount of water or go buy yourself a bottle of OEM G12 or G12+ coolant for top up purposes.
    But it could be indicating something else, have you seen any leaks / puddles in your Garage?
    Nov 2006
    More than likely just warning you about the level. Same thing happened to me a few weeks a go. I checked -- no leaks, but level just below minimum -- topped it up with coolant and I've had no lights since.
    That sensor must be very sensitive, because mine was just below the min mark.
    Mar 2007
    Gold Coast
    My coolant light came on with the level down a bit after about 30000ks.. guessing the polos just spit a bit of coolant out over time as I havent seen any puddles/ leaks
    NO! please do not topping it up with water!! go buy a G12 or G12+, mix it with distilled water and top it up to your polo
    This is what you need, i have instruction at the back
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Nov 2007
    I had to top up within the last week as well. Coolant less than $20 from VW. Must be the season for it .....
    Feb 2007
    Brisvegas
    I noticed on the weekend while polishing / detailing that my water was a little bit low (still above the min mark) after going for a quick drive...
    Was a lil bit worried but sounds like the 20v uses a little bit of water
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    Nov 2006
    A little bit of distiled water never hurt anything - But if you have to put more than a couple of hundred mils go with G12. (IMO)
    Jan 2008
    Just remember that the coolant also has the job of lubricating your waterpump, it's not just a anti-freeze/anti-boil and anti corosion green stuff (or red).
