Just top it up with water, it is fine.On a service it the strength should be checked and added if required.
1.5Lt G12+ purchased today from South Yarra Vw $13.25 in GST
Demineralised water 4lt $5 Bunnings
Now for the stupid woman questions
What mix do you make 2:3 , 1:1 or 3:2
Do any of you to keep some mixed up in your boot incase of emergencies?
Best way to flush? Read on another VW site empty, fill with normal water run for 2 days, empty and refil with G12 mix (It was sold to me like 3 months ago and has green coolant in it)
I know im in "polo" but do cordobas have roughly the same capacity, think 4 Lts?
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Maybe I should have been a bit more clear in that post. I didnt mean the coolant on its own is a lubricant (even though it stops builup on the waterpump), I meant the cooling system as a whole.
I had to learn this the hard way when an object got between the fan and radiator and chopped up the radiator and emptying all its contents. The car was towed home and I started it to drive it into the garage from the street, a distance of about 10-15 meters. That was a big mistake because the seals had no water/coolant to lubricate and just running the engine for about 15 seconds was enough to make the waterpump seals fail.
Mine came on before. Hadn't seen it before. Of course first reaction, "F**f what now? Red flashing thermometer in angry red water. Also flashing. This can't be good."
Mine turned out to be JUST on or under the minimum.
Read this and fretted over the water/coolant thing. Thought bugger it and put 8/10s of a small glass of water into it. Problem solved.
A trick I learned with mine.... if the coolant light comes on just after start-up, turn the car off, wait 5 seconds, turn it back on.... problem gone. Magically more coolant appears in the reservoir. God only knows where the coolant goes but it must get locked up somewhere or get an air bubble.... stuffed if I know but it comes back
If the light comes on when you're driving this is a different issue.
I've had coolant radiator problems for the past 6 months.
First the coolant light on... Then a couple months later on again.... Then once per week. Bought a new radiator now and will swap at next service.
Now the bloody radiator fan doesn't work (fuse is ok) so the car starts to overheat (never to the red) after an hour in traffic.
Stupid bloody cooling system
