Results 1 to 6 of 6
Thread: Coolant Leak
    Jul 2014
    Coolant Leak
    Hi All,
    Over the past 3 weeks i have had to top up about 300-400ml of coolant i can see a TINY drip on car cool down at the bottom of the radiator passenger side. I am going to pull the bumper off this weekend to make sure its not a house or a clip (easy fix) if its the radiator where could i source a replacement? its for a 2006 GTi. is it a home job? or should i source the parts and take it to the mechanic?
    Cheers.
    2006 Polo GTI | APR Stage1 | PD160 | K&N Panel filter | Forge TIP | Forge DV | Forge IC Piping | Milltek TBE |
    | Forge Front/Rear Strut Braces | SEAT RCA Bushes|
    May 2007
    I may be wrong, but I think this is a fairly common failure on the 9n3. Bottom passenger side of the radiator cracks, next to the outlet (inlet?). Had mine replaced around 2010, and that was a 2006 with about 120k on the clock. It was cracked for a while at that point, it doesn't loose a lot, but you do need to top it up every couple of weeks. It was like that for a while.
    Jul 2014
    Yeh sounds like mine. The loss is super minimal but should probably fix it sooner rather then later. I guess mods are on hold for the moment. Just as so picked what wheels I wanted
    Jul 2014
    So I'm thinking it's a intermittent issue. No coolant loss this week at all. I tightened all the clamps and hoses so hopefully that fixed it.
    Jan 2009
    blankedy
    If its <500ml a year, I woudn't be worried if you keep an eye on it. The light on the dash goes on before you loose any real volume of fluid.
    Aug 2011
    Brisbane North
    Got mine done just over a year ago. Radiator cost me about $220 then but the labour was what really bent me over. All up cost me about $930. Worst part is that it might be leaking again.
    Some say...
