Results 1 to 5 of 5
Thread: Coolant Consumption
    Thirroul N.S.W
    Coolant Consumption
    My GTI seems to be consuming coolant at a rapid rate. I filled it up about 8 weeks ago as the coolant light was coming on and only yesterday the light came on again. Checked the level and it is back down below minimum.
    Anyone else had an issue? Any ideas what could be causing this? It isnt leaking so i has to be going somewhere.
    Jan 2009
    blankedy
    could be the old radiator issue a few have had. I'd look for the thread on it, i think there is a common issue near the top left / right.
    Aug 2009
    Check around the thermostat, from memory that is the common leak point most Polo's have.
    Only fix is to get a new radiator
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Aug 2007
    think i would have it pressure tested, thats how to check for coolant leaks. Radiator issue is round the temp switch left side, not thermostat.
    cheers
    Jmac
    Alba European
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by DomGTI View Post
    It could be a slight head gasket leak either going into the exhaust or could be leaking into the engine ,did you check the oil if its milky looking there's the problem.
    Depending on how many km you've done since the last top up it may pay to take of the radiator cap while the engine is running and check for any bubbles that will show if its the head gasket.
