bump... anyone???
Has anyone done this mod? i read from Guy's camp that there is a CDA by BMC that we can use... the reason why i want this is because logically if your going to put an exhaust on, you should theoretically equal that out with more a more unrestrictive inlet. any other companies make a similar apparatus? also guy, when you change the battery... how do you go about all those small leads on top? if i take it to a battery specialist will they know what to do? sorry... my mechanical aptitude is quite good... electrical up to ****.
bump... anyone???
the new generation vws seem to have a pretty well sorted air intake from the factory dont they?
I know the golf V has a reasonable setup that ducts air from the front. doesnt the polo have a similar setup?
It looks quite restrictive to me.......
Yeah it does feed from the front put the pipe that feeds has only got to be like 50mm wide.
But im sure u could get some flameproof brake ducting 100mm and replace it and maybe a little triming to fit it into the airbox.
Maybe try that before outlaying hundreds for a pod in a carbon cylinder, the standard box isnt that bad after all there aint any secret compartments for emissions so it looks fine.
