Results 1 to 5 of 5
Thread: Cold Air Induction
    Jan 2007
    canberra
    Cold Air Induction
    Has anyone done this mod? i read from Guy's camp that there is a CDA by BMC that we can use... the reason why i want this is because logically if your going to put an exhaust on, you should theoretically equal that out with more a more unrestrictive inlet. any other companies make a similar apparatus? also guy, when you change the battery... how do you go about all those small leads on top? if i take it to a battery specialist will they know what to do? sorry... my mechanical aptitude is quite good... electrical up to ****.
    Jan 2007
    canberra
    bump... anyone???
    Point Cook, Vic
    the new generation vws seem to have a pretty well sorted air intake from the factory dont they?
    I know the golf V has a reasonable setup that ducts air from the front. doesnt the polo have a similar setup?
    FOLLOW US ON FACEBOOK
    Jan 2007
    canberra
    It looks quite restrictive to me.......
    Yeah it does feed from the front put the pipe that feeds has only got to be like 50mm wide.
    But im sure u could get some flameproof brake ducting 100mm and replace it and maybe a little triming to fit it into the airbox.
    Maybe try that before outlaying hundreds for a pod in a carbon cylinder, the standard box isnt that bad after all there aint any secret compartments for emissions so it looks fine.
Similar Threads
  1. Induction mouth
    By WRXconvert in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 08-03-2007, 10:18 AM
  2. ABF cold start
    By golf3 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-02-2007, 08:26 AM
  3. Cold Air Intake (with MAF sensor)
    By midget in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 18-10-2006, 11:35 AM
  4. Car hard to start on cold startup
    By Golf Loon in forum Mk2 Golf & Jetta
    Last Post: 08-11-2005, 09:47 PM
