yes the clutch is hydraulic and it feeds off the brake fluid reservoir.
The clutch should be bled the same time as the brakes (every 2 years according to ELSAWIN).
To gain access to the clutch actuator bleeder valve - You'll need to remove the intake pipe ( having skinny arms and hands is a bonus, it's damn tight in there ), the actuator is below the pipe on top of the gearbox.
