Surely something up with the flywheel - it sounds worse than a diesel! I've posted a video in the What Did You Do Today thread, can you share your experience?
It's unfortunately a standard side effect with the light weight flywheel mate. I have the same one from ECS. I do however remember Jimmy saying a part fix is using a new OEM bearing not the ECS one. He did this with mine and I only hear the chatter noise at idle when I have the aircon pumping. But even then a little rev will usually help dissipate it.
Hope it helps!
sorry - I'd started a new thread on this same problem as what Kaanage had experienced until I dug this one out of the achive.
I too have this knocking when the engine is ever so slightly loaded/unloaded with the throttle at low rpm.
To test whether the front wheel bearing preload stretch nut has loosened (it may have since both inner driveshaft boots were done on the car the year before I bought it) I plan on tightening it slightly and then seeing if the knocking goes away. If it does i'll order new stretch nuts but I'm unsure how to do the preloading. I'm ok with the castellated nut/cotter pin method but that requires you to take up the tension and then back off from there to a running postion. But I'm unsure if this is the way to go with a stretch nut which by definition shouldn't be backed off from its final position as this voids its ability to hold a certain torque setting doesn't it? Or are they fitted with a torque wrench setting?
So how do I go about finding the correct pre load considering also that the original bearings ( 6yo 28k km) will likely remain in the car?
thanks for any help
sam
Actually, the hub replacement didn't quite eliminate the noise - it did reduce it to just a 4th and 5th gear issue at low rpm (see Misdiagnosis by dealer - what next? for more details). There may have been a slight amount of stretch on the hub nuts but it could also have been the bolts holding on the control arms (I had the SEAT Cupra rear bushes installed at the same time).
The noise finally went away after I installed some subframe sleeves that Eddy had made up a while ago (I bought the last set).
Sorry for not updating this thread properly back in the day but it died with the tangent discussion about lightweight clutch replacements and I didn't think anyone was still interested in the original issue. I will see if I can get the torque for the hub nuts for you.
edit
BTW sambb, your inbox is full so I couldn't reply to your PM on this so I'd check the bolts for the front control arms and subframe as they seem more likely culprits to me, now.
Resident grumpy old fart
righto, thanks for getting back to me on the forum. It really is a chorus of noises in front of me now. Even though everything looks to be ok its going to cop a complete re bush after I check the front hub nuts. If that doesn't do it i'll order a new set of subframe stretch bolts.
thanks
sam
Hi Sambb, a PM to Eddy would be wise.
Eddy has done lots of work and sorted thru the front subframe, LCA etc etc on our Polos. Eddy also found that the LCA front bolt was 1.5mm smaller than the sleeve it goes into to. So he brought new bolts with thread all the way along the bolt, result- no more movement slack!
I am sorting my front end out prior to fitting new front & rear suspension and bushes etc. cheers Al
Hmmm. I have to disagree with Eddy on this one - there are sound engineering reasons for the VW arrangement with the LCA front bolt. The thinner shaft ensures that the maximum stress is in this area rather than at the thread roots which GREATLY enhances the fatigue life of the bolt. With the full length thread the bolt will fail earlier since the thread roots are stress raisers.
It would be much better to add a polyureathane sleeve (fitted via a spiral slot if it's too stiff for a lengthwise slot)
The subframe sleeves I mentioned before are a great idea, though
So the standard bolts only have thread where its needed but this undersizes the shaft along the pivot. hmm thanks for that. I have access to a whole variety of high tensile bolts at work to at least try out temporarily on the front LCA bushes to eliminate that. High tensiles will be strong enough/safe won't they? VW don't have any super metallurgy going on with simple bush cross bolts do they, other than the potential issue that kaanage raised?
For a short period, a fully threaded bolt of the same quality as the OE one would be OK - fatigue failure is a long term issue for most parts (a lot of cars would never have this bolt removed in their lifetime), unless the part was critically optimised in the first place and I'd lay long odd that this one isn't.
Why not just wrap the shank of the OE bolt with some sheet metal?
Hoyhoy.
Sorry folks I only just spotted this thread, Greg the threaded shank bolts were the replacement part from VW, plus I did add some sleeving on
the little bit of blank shank left, on top of that there is added material as to where it goes in (thickness & minumun diameter)(zero freeplay).
Info a lot of VW bolts are of 12.2 tensile grade, normal hi-tensile = 8.8.
Hooroo.
