OK, finally got another torque arm with a ployureathane bush (APR fast road) and had it installed. Again, the clunking has been reduced but it's still there
While the car was up on the hoist we rechecked the driveline and the only thing noticable is a slight amount of backlash in the differential (nothing at all at the CV joints). My mechanic thought the amount of backlash was pretty normal but also that the Polo (VAG cars) may be tighter in this area than the cars he normally deals with.
So the cure would seem to be a new diff
Resident grumpy old fart
