Guess when you go out on the track and drive the wheels off it, things will happen.
Do you mean when you back off the power? Could be swaybar links, by car does it when i am backing off the power hard, but its a lot lower than yours
Does anyone know why my car has started to make a slight "clunk" sound when the engine loading reverses?
It wasn't doing it before the weekend
MODS- TOO MANY
It happens even when the transitions are really gentle like if I feather the accelerator up and down
Do you think it could be an engine or gearbox mount? It's got less than 16,000km on it
Hmm...sounds like it could be engine or gearbox mount since you describe it happening that way.
That was my first thought, engine mount. If it's under warranty take it back. I had suspension components changed under warranty and I'd been tracking my car, and they changed the strut top mounts after I'd lowered it. IMO - unless you're being particularly aggressive (no mechanical sympathy) on the track, you're not too likely to break new components so I wouldn't be too worried about that aspect.
But I don't know your driving style
Daily: 2010 VW Jetta Highline
I drive like a granny - aiming for 1100km on this next tank.
OK back to the stealer she goes - an rattle has redeveloped in the door too, that they fixed after a previous cruise (might pull the CAMS sticker off 1st, though).
Just quickly undo your swaybar links and go for a drive to see if that fixes it. After a 'spirited drive' one day i came home and car was knocking when reversing out of my driveway. Was just my links loosened from the drive day.
MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
