All the sway bar does is spring up.All you need to do is jack it up centrally and take both off at the same time then the anti roll bar will be even but there is no adjustment whatsoever so they cant sit "incorrectly". This isnt the same as fitting a pressed bush, they are ball joints not bushes so just fit them and torque them up to spec and you are done, no special fitting procedure whatsoever. torque the nuts up to 40NM and you are done. All you are going to do is turn a very basic procedure into a tricky one. No need.
My 2c
Jmac
Alba European
Just on drop links ive arranged to have my short links to b matched at Fulcrums tomoz. Just to recap the links i talk about apart from OEM the short ones are for susp that has the LOW coilies, not just lowered as the OEM suffice but the extra low stuff like JASN78 and the likes
Jmac
Alba European
